Home > Maintenance & Modifications > JW speakers / lazer lights - MOT time |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2870 |
So I currently have this setup
Click image to enlarge But I am wondering what’s correct for MOT. I need to change the DRL bumper to turn off with side lights as they currently go off with dipped. The big 52” Lazer is a stand alone switch, but the Lazer ST4 come on with full? Is this ok? I can easily swap the spare plain grille in. Then are the Jw speaker lights ok? I am in NI, anyone put one thru a test centre with similar? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
5th Jan 2020 7:17pm |
Technically, any 'auxiliary' lights should be switched with the main beam. However, if your independently switched light bar is switched off, then it won't be an MoT issue. It's one of those things that's illegal to use (on the road) rather than illegal to own.
Your DRL's should go off with the side light lights. I wish more were as conscientious as you about them though, as there seem to be plenty of cars running around with them on all of the time, which is bloody nuisance. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th Jan 2020 9:45pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19577 |
Going around with front fog lights on with no fog is a favourite too. 🙄 Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
5th Jan 2020 10:56pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2054 |
Driving a modern car with NO lights seems to be the 'thing'..........basically because the dash lights must be on all of the time rather than more classic cars where you sat in darkness - DRL's only
Even spotted a local Plod at around 1am New Years Eve (Day really) that was showing no lights apart from DRL!!! Feckwits |
5th Jan 2020 11:27pm |
Thanks, I think to keep it simple I will just swap the grille to remove the ST4’s, light bar is completely independent on a switch and DRL off on sides. Andy
6th Jan 2020 12:20am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2626 |
You should be okay... reason i went with the rs8 on the a bar was i could run it off the high beam,
my triple r is on a switch tho. |
6th Jan 2020 6:33am |
Great should be ok then,
Next question: I have removed the 3rd row seats, but seat belts are still in place. I guess I should remove these completly otherwise they may insist on testing them into a seat buckle? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
8th Jan 2020 4:51pm |
If there are no seats, are they still seat belts?? Darren
8th Jan 2020 10:33pm |
I'd take them out, I believe they will 'test if items are fitted' but they 'do not and cannot remove covers to access items to test'. (This may have changed somewhat though.)
As LRA mentions that is a good statement, personally I'd just remove the opertunity for them to test them if they aren't going to be used. It then stops the questions being raised, for example 'seatbelts fitted, no adequate seating'. customer advised. What ever you do, don't have slippy side steps either come MOT time. Somone had that before too. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Jan 2020 10:46pm |
