Home > Maintenance & Modifications > JW speakers / lazer lights - MOT time
mcma1
So I currently have this setup
But I am wondering what’s correct for MOT. I need to change the DRL bumper to turn off with side lights as they currently go off with dipped. The big 52” Lazer is a stand alone switch, but the Lazer ST4 come on with full? Is this ok? I can easily swap the spare plain grille in.
Then are the Jw speaker lights ok?
I am in NI, anyone put one thru a test centre with similar? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #808863 5th Jan 2020 7:17pm
JW Speakers will be legal. If genuine which I’m sure they are.
Lightbar or spotlights are fine with main beam on or off. I use my dual front light bars switched on and off with main beam all the time. Personally I think it’s safer.
I believe a roof light bar needs to be on a switch though.
Others on here know the laws in more depth than I do though, but the basics I’ve listed about. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #808866 5th Jan 2020 7:21pm
Technically, any 'auxiliary' lights should be switched with the main beam. However, if your independently switched light bar is switched off, then it won't be an MoT issue. It's one of those things that's illegal to use (on the road) rather than illegal to own.
Your DRL's should go off with the side light lights. I wish more were as conscientious as you about them though, as there seem to be plenty of cars running around with them on all of the time, which is bloody nuisance. Darren
Post #808911 5th Jan 2020 9:45pm
Going around with front fog lights on with no fog is a favourite too. 🙄 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #808941 5th Jan 2020 10:56pm
90 Dreamer
Driving a modern car with NO lights seems to be the 'thing'..........basically because the dash lights must be on all of the time rather than more classic cars where you sat in darkness - DRL's only
Even spotted a local Plod at around 1am New Years Eve (Day really) that was showing no lights apart from DRL!!! Feckwits
Post #808947 5th Jan 2020 11:27pm
mcma1
Thanks, I think to keep it simple I will just swap the grille to remove the ST4’s, light bar is completely independent on a switch and DRL off on sides. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #808954 6th Jan 2020 12:20am
Likeomg
You should be okay... reason i went with the rs8 on the a bar was i could run it off the high beam,
my triple r is on a switch tho.
Post #808958 6th Jan 2020 6:33am
mcma1
Great should be ok then,
Next question: I have removed the 3rd row seats, but seat belts are still in place. I guess I should remove these completly otherwise they may insist on testing them into a seat buckle? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #809366 8th Jan 2020 4:51pm
If there are no seats, are they still seat belts?? Darren
Post #809434 8th Jan 2020 10:33pm
I'd take them out, I believe they will 'test if items are fitted' but they 'do not and cannot remove covers to access items to test'. (This may have changed somewhat though.)
As LRA mentions that is a good statement, personally I'd just remove the opertunity for them to test them if they aren't going to be used.
It then stops the questions being raised, for example 'seatbelts fitted, no adequate seating'. customer advised.
What ever you do, don't have slippy side steps either come MOT time. Somone had that before too. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #809440 8th Jan 2020 10:46pm
