Home > Maintenance & Modifications > Difference between a 90 and a 110 NAS step?
Co1
Is it just the brackets that go from the tow bracket the the chassis that are different, or is there more to it? I’ve got a chance of a second hand 110 step, but just want to check what I need to do to get it to fit my 90.
Col
Post #808198 31st Dec 2019 10:04am
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
When I bought mine it came with the fixing brackets for both the 90 and 110 so suitable for either application.
This should help explain the difference...
https://www.paddockspares.com/downloads/STC50301_vr1.pdf
Post #808206 31st Dec 2019 11:03am
90 Dreamer
As above pretty sure its simply a bracket issue rather than the actual step structure.......
Post #808220 31st Dec 2019 12:46pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
If it’s a genuine step, then it is an issue of structure. New aftermarket bumpers are built to be universal, the original ones are for a 90 or a 110. A 90 bumper would fit a 110 but the bottom stays would not reach to the frame rail. A 110 Parts would not fit a 90 because the bottom stays would be too long.
Post #808222 31st Dec 2019 1:33pm
Also be aware there's at least two variants of the rear step bumper. The key difference is in the end flanges where they attach to the rear crossmember.
Post #808324 1st Jan 2020 8:49am
JimC
And I forgot I was replying in a UK forum, so most of what you’re seeing over there is likely the universal-fit variety.
Post #808373 1st Jan 2020 4:01pm
Co1
Got it home today, it does indeed fit; just needs the support arms for a 90.
Post #808395 1st Jan 2020 6:37pm
