![]() | Home > Maintenance & Modifications > Difference between a 90 and a 110 NAS step? |
| X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212
When I bought mine it came with the fixing brackets for both the 90 and 110 so suitable for either application.
This should help explain the difference... https://www.paddockspares.com/downloads/STC50301_vr1.pdf |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308
As above pretty sure its simply a bracket issue rather than the actual step structure.......
| JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164
If it’s a genuine step, then it is an issue of structure. New aftermarket bumpers are built to be universal, the original ones are for a 90 or a 110. A 90 bumper would fit a 110 but the bottom stays would not reach to the frame rail. A 110 Parts would not fit a 90 because the bottom stays would be too long.
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Also be aware there's at least two variants of the rear step bumper. The key difference is in the end flanges where they attach to the rear crossmember.
And I forgot I was replying in a UK forum, so most of what you’re seeing over there is likely the universal-fit variety.
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3787
Got it home today, it does indeed fit; just needs the support arms for a 90.
| All times are GMT |
