![]() | Home > Puma (Tdci) > 2.2 fuel filter change procedure |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Always useful to have knowledge of other owners experiences
![]() 2008 SVX 90 2000 XS TD5 90 |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
If you pre-fill the filter before fitting too you can save the priming business, just start as normal and leave running for 5 minutes! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 ![]() ![]() ![]() |
I prefill the new filter then start/run engine at about 3000rpm for one minute. Never had any problem.
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Hello UtilityTruck,
Did it start up without any problem? Did you increase the RPMs on start? I don't like the idea of pre fuelling fuel filters just in case debris gets. Thanks Mark |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Did my 2.4 a couple of weeks ago and pre-filled the filter with a fuel treatment / additive. Just fired it up and left it running for 5 Mins.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Isn't there an in built purge cycle like the Td5's have? (ign on, pump the throttle pedal 5 or so times and it'll run the pump constantly for a minute or 3)
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Yes started as normal, no hesitation. No need to raise the revs at all. The in-tank pump and return style fuel system mean all the air is purged back into the tank. ![]() |
Replaced my filter this morning and bleed as described, no problem.
Started up first time. Much better then risking un filtered fuel getting in the HP pump while priming the filter. Thanks UT! |
xjahx Member Since: 30 Mar 2016 Location: Boston Posts: 7 ![]() ![]() ![]() |
Worked flawlessly.
For the avoidance of doubt, exactly which procedure did you use? There are a few procedures described in the topic.
I followed UtilityTrucks advise at the start of the this thread, worked a treat!
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
Useful information, thank you for posting.
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hi,
I did want to purge the diesel filtre ... Nothing was going out, so I decide to turn the key for 2 or 3 secondes ... The key out, the cycle of pumping was going to the end. My surprise was to see that with one cycle there was 0.6 litre in the container ! So I think that it is not neccessary to make 10 cycle, I will try with 3 next time I change the filtre Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Interesting to hear Philippe, I was simply going on the sound, which changed on the 7th cycle so really I have no idea how many cycles were required to actually purge the filter- I played it safe I suppose! 2014 Keswick Utility 2.2
