Home > Maintenance & Modifications > Jate Rings
JSG
Jate Rings
Daft question time.
I've taken the lashing rings off the front of the chassis this evening (noticed a bit of surface rust on the chassis already .. ) and gone to fit the jate rings I kept from the 07 Puma.
The jate rings are wider than the chassis and I can't remember if I packed them out with washers last time. Should they be packed out with washers to give a more snug, rattle free fit or left loose?
Cheers,
John John
2011 Tdci 110 CSW XS
Post #76309 16th Jun 2011 8:22pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I packed mine out a bit so there was a bit of movement
Post #76329 16th Jun 2011 9:41pm
markb110
Hi JSG
Make sure that you can still move them with your finger.
At club events i have recovered vehicles but then unable to unhitch either a shackle or winch hook because the jate ring has jammed up against the chassis because it was too tight in the firt place.
All the best
Mark
Post #76338 16th Jun 2011 10:19pm
