![]() | Home > Td5 > Camshaft specs |
| Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412
Just fyi
10p or 15p they share the same camshaft. Only difference was 0,5mm increase for the inj lift only. The rest are identical. More info to come later Can't leave well enough alone |
| Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845
Are you contemplating reprofiling the cam ?
Yes, i found the intake and exhaust Valve lift is 8mm, and any more will lead to the springs binding.
Lets see what my cam shop says about increasing the duration of the cam. Can't leave well enough alone |
