Home > Td5 > Camshaft specs
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Camshaft specs
Who knows the 15p camshaft specs?
Duration at 0.006” and 0.050”
Valve Lift
Injector lift
Thank you Can't leave well enough alone
Post #807243 22nd Dec 2019 6:14pm
Naf
Just fyi
10p or 15p they share the same camshaft.
Only difference was 0,5mm increase for the inj lift only. The rest are identical.
More info to come later Can't leave well enough alone
Post #868160 18th Nov 2020 6:05pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Are you contemplating reprofiling the cam ?
Post #868167 18th Nov 2020 6:49pm
Naf
Yes, i found the intake and exhaust Valve lift is 8mm, and any more will lead to the springs binding.
Lets see what my cam shop says about increasing the duration of the cam. Can't leave well enough alone
Post #868240 19th Nov 2020 7:04am
