Home > Technical > Wheel nut/stud thread size
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
Hi
Does anyone know the thread specification on standard Defender wheel nuts/studs please?
Post #806341 15th Dec 2019 7:32pm
sako243
Google?...
M16x1.5 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #806359 15th Dec 2019 8:31pm
foggydave
Thank you Sako 243
Post #806368 15th Dec 2019 9:34pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Yes - note that it's finer than the standard M16 thread used by tow hitch bolts etc. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #806431 16th Dec 2019 11:24am
foggydave
Hi
ISO ANSI/ASME B1.13M-19195 standards for M16 threads give
M16 X 2
M16 X 1,6
M16 X 1,5
M16 X 1,25
M16 X 1
M16 X O,75
M16 X 0,5
So was a little unsure when measuring the pitch between 1.5 and 1.6
Also it would be goodneed know the (Pitch Circle Diameter) PCD of the studs if anyone knows it. I can take a template but the true figure would be more accurate.
I am mackling up a turntable gizmo using an old front hub assembly.
Post #806453 16th Dec 2019 1:47pm
rallysteve
PCD is 5x165.1mm and centre bore size should be 114.3mm but i suspect rust may have resulted in a bit of tolerance on that over the years on a second hand hub.
Post #806456 16th Dec 2019 2:03pm
alex_a
United States
is it also same M16x1.5 for new defender?
Post #941346 7th Feb 2022 12:26am
alex_a
United States
nevermind, it's M14 x 1.5 for new defender
Post #941347 7th Feb 2022 12:30am
