![]() | Home > Technical > Wheel nut/stud thread size |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
Google?...
M16x1.5 Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 ![]() ![]() ![]() |
Thank you Sako 243
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Yes - note that it's finer than the standard M16 thread used by tow hitch bolts etc. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Hi
ISO ANSI/ASME B1.13M-19195 standards for M16 threads give M16 X 2 M16 X 1,6 M16 X 1,5 M16 X 1,25 M16 X 1 M16 X O,75 M16 X 0,5 So was a little unsure when measuring the pitch between 1.5 and 1.6 Also it would be goodneed know the (Pitch Circle Diameter) PCD of the studs if anyone knows it. I can take a template but the true figure would be more accurate. I am mackling up a turntable gizmo using an old front hub assembly. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
PCD is 5x165.1mm and centre bore size should be 114.3mm but i suspect rust may have resulted in a bit of tolerance on that over the years on a second hand hub.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
alex_a Member Since: 06 Feb 2022 Location: Los Angeles Posts: 4 ![]() ![]() |
is it also same M16x1.5 for new defender?
nevermind, it's M14 x 1.5 for new defender
