Home > Puma (Tdci) > Help needed oil leak and water leak
fatboyron
Hello there
First one got an oil leak on the left hand side of the engine under the manifold.
Please see picture.
Is the cylinder head gasket maybe going or something else?
Any help will be appreciated.
And the water leak.
I got in it the other day and noticed a tiny bit of water down by the clutch pedal on the mat.
Today it had trouble starting but did start and there was a bigger puddle there.
Going along I noticed the sidelight symbol was on the dash but lights were turned to off. As soon as I turned the lights on the sound on the stereo went off.
Tomorrow I will seal the bulk head to window frame to see if that stops it.
I'll let it dry out and see what happens, any advice on what it could be?
I did have the clutch done last week and this has happened since then but I can't see a connection.
Post #806192 14th Dec 2019 6:04pm
Eduardo
Regarding the water keak: Are you sure that is water?
Can be the oil from the clutch master cylinder tht usually drops from the clutch to the mat (quite common fault at lest in mine)
Cheers and good luck with the engine oil leak Eduardo
Post #806221 14th Dec 2019 9:08pm
fatboyron
yeah it's definitely water I check the master cylinder because my clutch went a couple of weeks ago and that's one of the first things I checked as well but there's no water today so no clue
Post #806332 15th Dec 2019 6:32pm
fatboyron
Hello there
Just posting a reply to see if I can get some information.
I've still got an oil leak and it is coming from between the cylinder head and the cam shaft housing In the picture it the top part.
I just wondered what is used to seal between these two?
Post #825848 16th Apr 2020 6:48pm
