![]() | Home > Puma (Tdci) > Help needed oil leak and water leak |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Regarding the water keak: Are you sure that is water?
Can be the oil from the clutch master cylinder tht usually drops from the clutch to the mat (quite common fault at lest in mine) Cheers and good luck with the engine oil leak Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 ![]() ![]() |
yeah it's definitely water I check the master cylinder because my clutch went a couple of weeks ago and that's one of the first things I checked as well but there's no water today so no clue
Hello there
Just posting a reply to see if I can get some information. I've still got an oil leak and it is coming from between the cylinder head and the cam shaft housing In the picture it the top part. I just wondered what is used to seal between these two? ![]() Click image to enlarge |
