![]() | Home > Maintenance & Modifications > Alternator wiring |
![]() Click image to enlarge Two larger spades DC + out (red ) Small spade charge lamp (orange ) ![]() Click image to enlarge Last edited by dorsetsmith on 7th Dec 2019 5:35pm. Edited 1 time in total |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1639 ![]() ![]() ![]() |
Hi dorsetsmith thank you
![]() ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6699 ![]() ![]() ![]() |
Leave your main power lead as it is
Is the terminal marked B+ or D+. ?
Hi I hadn’t even noticed the letter I just saw the + it looks like B+
as martin main power lead (starter sol Battery + ) can go to the large spades or the B+ terminal and your charge lamp - IND to D+ or small spade
w terminal is tacho output i.e. RPM gauge |
Hi dorsetsmith and Martin Thank you both very much I will do that in the morning
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2541 ![]() ![]() ![]() |
We're extremely lucky to have Dorsetsmith and Martin on our forum with their expert knowledge of electickery. Barneyboy's problem solved within literally minutes.
![]() Mini Countryman Cooper S Morgan Plus 8 |
We definitely are 100%
