Home > Maintenance & Modifications > Alternator wiring |
Click image to enlarge Two larger spades DC + out (red ) Small spade charge lamp (orange ) Click image to enlarge Last edited by dorsetsmith on 7th Dec 2019 4:35pm. Edited 1 time in total |
7th Dec 2019 4:05pm |
Barneyboy Member Since: 19 Nov 2014 Location: Oxfordshire Posts: 1582 |
Hi dorsetsmith thank you , I have connected the new one with the solenoid cable to this terminal as it already had a ring connector on it can I still leave it on there and just put the charge light on to the small spade connector or should I replace the ring connector with a large spade connector and plug them both in to that same block cheers Paul
Click image to enlarge |
7th Dec 2019 4:29pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6460 |
Leave your main power lead as it is 1988 90 Td5 NAS soft top
2015 D90 XS SW |
7th Dec 2019 4:50pm |
Is the terminal marked B+ or D+. ?
Hi I hadn’t even noticed the letter I just saw the + it looks like B+
7th Dec 2019 5:01pm |
as martin main power lead (starter sol Battery + ) can go to the large spades or the B+ terminal and your charge lamp - IND to D+ or small spade
w terminal is tacho output i.e. RPM gauge |
7th Dec 2019 5:27pm |
Hi dorsetsmith and Martin Thank you both very much I will do that in the morning cheers Paul
7th Dec 2019 5:29pm |
Hi dorsetsmith and Martin I couldn’t wait until the morning I’ve just been out and fitted the correct spade terminal and fitted it and sure enough the charge light has gone out as soon as it started thank you both very much it’s very much appreciated cheers Paul
7th Dec 2019 5:56pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2494 |
We're extremely lucky to have Dorsetsmith and Martin on our forum with their expert knowledge of electickery. Barneyboy's problem solved within literally minutes. Defender 90XS SW
7th Dec 2019 6:14pm |
We definitely are 100% my problem went from a 1/2 hour job to a head scratching afternoon and am very grateful for the advice given and problem solved in minutes cheers Paul
7th Dec 2019 6:19pm |
