Home > Wheels & Tyres > Sankey tyres
Avelingporter
Sankey tyres
My Sankey trailer has ex mod 6.50 x 16 tyres. Looking a bit old and cracked.
Probably ok but would like to replace with more modern tyres and wheels.
If using 16” rims, say a wolf steel for instance, what size tyres would give me the same rolling dia as the original 6.50? I don’t want to raise the trailer. It has taken a lot of effort to get to tow at the correct nose down attitude.
I remember vaguely early discos on something like 215-70 x16, but not sure. Would they work.
Thoughts please.
Douglas
Post #801998 12th Nov 2019 10:25pm
Co1
Have a play here and see what gets you closest.
https://www.tyremen.co.uk/tyre-size-calculator
Post #802027 13th Nov 2019 7:08am
Grouse
235/85/16 are recognised as a direct replacement for 7.50’s and almost the same diameter
Post #802032 13th Nov 2019 7:41am
They're a lot bigger than the 6.50's that the OP talks about though Confused Darren
Post #802037 13th Nov 2019 8:57am
Re: Sankey tyres
In terms of diameter, a 235/70 is the closest. They'd be ok on Wolf rims but not on original Sankey steel wheels as they'd be too narrow. Darren
Post #802038 13th Nov 2019 9:01am
Stacey007
Hello
I use the same as on my truck, that way I have a spare when towing Smile
Same make / size 235/85/16 conti's
Post #802040 13th Nov 2019 9:14am
Grouse
Perfect choice Thumbs Up Cool that’s why I recommended them as above ^^^ assuming the OP is on OE 235/85’s - most newer Ex Mod LR trailers Penman / Sankey type are also fitted with this size for that reason
Post #802095 13th Nov 2019 4:59pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
I run my Narrow track on 205R16's and they didn't make any difference to towing height when fitted to replace the old 6.50's Used the original military rims too. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #802122 13th Nov 2019 7:54pm
Avelingporter
Thanks LRA and DR. Sounds like you are closest. Yes they are 6.5 on the small rims. It’s a mk2 trailer I think. Wider but still on drum brakes.
Post #802164 13th Nov 2019 11:14pm
