![]() | Home > Wheels & Tyres > Sankey tyres |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
Have a play here and see what gets you closest.
https://www.tyremen.co.uk/tyre-size-calculator |
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 538 |
235/85/16 are recognised as a direct replacement for 7.50’s and almost the same diameter
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
They're a lot bigger than the 6.50's that the OP talks about though
In terms of diameter, a 235/70 is the closest. They'd be ok on Wolf rims but not on original Sankey steel wheels as they'd be too narrow. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3892
Hello
I use the same as on my truck, that way I have a spare when towing Same make / size 235/85/16 conti's Click image to enlarge |
Perfect choice
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926
I run my Narrow track on 205R16's and they didn't make any difference to towing height when fitted to replace the old 6.50's Used the original military rims too. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
| Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 409
Thanks LRA and DR. Sounds like you are closest. Yes they are 6.5 on the small rims. It’s a mk2 trailer I think. Wider but still on drum brakes.
