Home > Puma (Tdci) > MAP Sensor
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
MAP Sensor
When I took my MAP sensor out it was covered in oil which I’m assuming is not a good thing. What should I be checking?
Post #801900 12th Nov 2019 10:44am
Bluest
It'll probably just be oil returning to the manifold via the engine breather pipe. A catch can may fix it if is a really bad. Otherwise, a periodic clean of the sensor when you service the car will probably suffice. 2007 110 TDCi Station Wagon XS
Post #801907 12th Nov 2019 11:23am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Mine was the same, a quick spray of contact cleaner fixed it.
I wouldn’t worry about it, just clean them once a year.
Post #801909 12th Nov 2019 11:37am
X4SKP
Hello boxoftricks
Sorry MAF not MAP advice given... now edited Shocked SKIP
Post #801910 12th Nov 2019 11:39am
boxoftricks
Thanks guys, appreciate the advice as ever Thumbs Up
Post #801924 12th Nov 2019 12:57pm
