Home > Maintenance & Modifications > Wheel Spacers
Page 2 of 2 <12
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Hi All
I just installed TF wheel spacers on my 90.
Before installation I had a slight wheel tremor at around 80 Kmh.
Now after fitting the spacers it’s progressed to full on death wobble between 70 and 80 klicks.
Any thoughts? I’m thinking the spacers are not the cause but they have only accentuated the original issue.
I guess next steps is to start changing all the rubber mounts ?
Any advise please
Thanks
Kev
Post #964508 9th Sep 2022 4:17pm
Changing the offset will, unfortunately, greatly amplify any imbalance or wobbliness as you have found. I would probably start with the simplest thing and get the wheel balance checked, since a slightly out of balance wheel will feel like a catastrophically out of balance wheel now.
After that you really just need to check that wheelbearings, swivels, and all steering balljoints are all up to spec, then move on to other steering and suspension components.
Post #964517 9th Sep 2022 5:23pm
Kevlar
Thanks for the advise Blackwolf
Good to know where to start next.
Let’s hope it’s the wheel balancing Very Happy
Kev
Post #964519 9th Sep 2022 5:38pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Kevlar wrote:
Hi All
Any advise please
Thanks
Kev
Could be as simple as wheel balancing, but also highly likely to be showing up some play in other suspension/steering components.
Have a read of this - https://www.defender2.net/forum/topic84803.html
Post #964606 10th Sep 2022 11:48pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Scrub Radius. Also makes keeping straight whilst breaking much harder. m
Post #964608 11th Sep 2022 3:10am
Kevlar
Thanks all
I’ll start with the wheel balance and work in from there.
My swivels are pitted and leaking so expect they are worn and contributing to the issue.
Just added a few more things to my defender to do list Very Happy
Kev
Post #964611 11th Sep 2022 7:14am
Kevlar
So, I had my wheels balanced, they were all out of balance so definitely worth doing.
Unfortunately, it didn't solve the death wobble.
For now, I have removed the spacers on the front until I get the issue solved.
Time to start spending some money on parts Smile
I will update once I find the solution.
Thanks
Kev
Post #964865 13th Sep 2022 12:32pm
100inch
Also check bushes, particular panhard rod. Your steering arm is may loose. Swivels, steering dampener.. the list goes on. The bigger the scrub radius, the bigger the tendency the car gets out of line, particular under braking. m
Post #964952 14th Sep 2022 5:54am
Poulstonb
Running terrafirma 30mm spacers no issues so far
Post #967047 7th Oct 2022 8:55pm
Kevlar
Hello
So I just finished installing Super Pro bushes to the Panhard Rod and Radius Arms.
The Death Wobble has gone. Honestly, it's never driven so well since I bought it.
Great result all round, tomorrow I will add back the wheel spacers and hopefully all will remain good.
Thanks all for the advice
Kev
Post #968897 25th Oct 2022 5:35pm
Page 2 of 2 <12
