|  | Home > Maintenance & Modifications > Wheel Spacers |
| Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84      | Hi All
 I just installed TF wheel spacers on my 90. Before installation I had a slight wheel tremor at around 80 Kmh. Now after fitting the spacers it’s progressed to full on death wobble between 70 and 80 klicks. Any thoughts? I’m thinking the spacers are not the cause but they have only accentuated the original issue. I guess next steps is to start changing all the rubber mounts ? Any advise please Thanks Kev | ||
|  9th Sep 2022 4:17pm |
| Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84      | Thanks for the advise Blackwolf
 Good to know where to start next. Let’s hope it’s the wheel balancing   Kev | ||
|  9th Sep 2022 5:38pm |
| I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 886      |
 Could be as simple as wheel balancing, but also highly likely to be showing up some play in other suspension/steering components. Have a read of this - https://www.defender2.net/forum/topic84803.html | ||
|  10th Sep 2022 11:48pm |
| 100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411      |
 Scrub Radius. Also makes keeping straight whilst breaking much harder. m | ||
|  11th Sep 2022 3:10am |
| Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84      | Thanks all
 I’ll start with the wheel balance and work in from there. My swivels are pitted and leaking so expect they are worn and contributing to the issue. Just added a few more things to my defender to do list   Kev | ||
|  11th Sep 2022 7:14am |
| Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84      | So, I had my wheels balanced, they were all out of balance so definitely worth doing.
 Unfortunately, it didn't solve the death wobble. For now, I have removed the spacers on the front until I get the issue solved. Time to start spending some money on parts   I will update once I find the solution. Thanks Kev | ||
|  13th Sep 2022 12:32pm |
| 100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411      | Also check bushes, particular panhard rod. Your steering arm is may loose. Swivels, steering dampener.. the list goes on. The bigger the scrub radius, the bigger the tendency the car gets out of line, particular under braking. m | ||
|  14th Sep 2022 5:54am |
| Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 92    | Running terrafirma 30mm spacers no issues so far | ||
|  7th Oct 2022 8:55pm |
| Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 84      | Hello
 So I just finished installing Super Pro bushes to the Panhard Rod and Radius Arms. The Death Wobble has gone. Honestly, it's never driven so well since I bought it. Great result all round, tomorrow I will add back the wheel spacers and hopefully all will remain good. Thanks all for the advice Kev | ||
|  25th Oct 2022 5:35pm |
| Posting Rules
