Home > Puma (Tdci) > Additional switch positions on tdci dash |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Have a look at mudstuff.co.uk who do a dash top mount and right-of-centre mount with Carling switches to suit both orientations. Both are good bits of kit. They also do a 3rd option utilising the standard LR switches.
If you're interested in fitting a subwoofer, I can also recommend the farcorners.co.uk under cubby sub enclosure which comes with a custom switch panel Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
14th Oct 2019 12:02am |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Not wanting to cut up the dash , I’ve placed front and rear light switches on the cubby box .
As said the carling switches and panels from Mudstuff leave a factory look that marries up with the rest of the dash . Depending on your spec you may have some blanks in your dash . Not entirely sure where you buy switches that fit them but could swear I’ve seen them for sale somewhere! https://www.instagram.com/hustynminepark/ |
14th Oct 2019 8:00am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
I did this with the Mud Pod as I fitted a flip out head unit which masked the switches. Made up some new wring loom extensions etc and also fitted the Disco hazzard switch. (and an oil temperature gauge)
Also fitted the Mudstuff single din holder assembly (passenger lower shelf) and then fitted a crafted switch frame assembly that allows fittment of 3 standard defender dash switches. (no phote atm) 2015 90 XS Santorini Black |
14th Oct 2019 8:53am |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1799 |
I fitted the switch for my rear worklight in the steering column shroud. Pre-2014 models even had a blank hole there I believe
Click image to enlarge 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
14th Oct 2019 3:57pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
I had a sub-woofer box fitted below the cubby, primarily for somewhere to fit additional USB's for front and middle seat passengers. But it has a panel on front where you can fit a bank of extra switches.
Click image to enlarge Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
14th Oct 2019 4:15pm |
leonvh Member Since: 31 Dec 2013 Location: Plombières Posts: 68 |
Click image to enlarge |
15th Oct 2019 6:49am |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
Where did you get the Heated Mirror switch from?
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
10th Nov 2019 7:26pm |
https://bearmach.com/switch-assembly-heate...s-ba-10307 |
10th Nov 2019 7:53pm |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 160 |
I used a replacement drinks holder insert in the cubby box. Leaves a holder on the passenger side but has a cutout for 3 carling switches on the drivers side.
Bought it from one of the usual online retailers . Let me try and find a link... |
13th Nov 2019 7:03am |
https://www.paddockspares.com/cubby-box-ac...s-usb.html
A few options too like a 2 switch holder that retains both drink holders... |
13th Nov 2019 7:09am |
