Home > Puma (Tdci) > Additional switch positions on tdci dash
peterl
1987 Defender 90 300 Tdi HT Epsom Green
I am interested to see where people locate additional switches (rear work light and front spots), I have heated seats, a/c and electric windows so all factory switches are utilised and am looking for options and suppliers of said switches.
Thanks
Pete
Post #798013 13th Oct 2019 10:12pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Have a look at mudstuff.co.uk who do a dash top mount and right-of-centre mount with Carling switches to suit both orientations. Both are good bits of kit. They also do a 3rd option utilising the standard LR switches.
If you're interested in fitting a subwoofer, I can also recommend the farcorners.co.uk under cubby sub enclosure which comes with a custom switch panel Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #798020 14th Oct 2019 12:02am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Not wanting to cut up the dash , I’ve placed front and rear light switches on the cubby box .
As said the carling switches and panels from Mudstuff leave a factory look that marries up with the rest of the dash .
Depending on your spec you may have some blanks in your dash . Not entirely sure where you buy switches that fit them but could swear I’ve seen them for sale somewhere! https://www.instagram.com/hustynminepark/
Post #798028 14th Oct 2019 8:00am
Vitesse
I did this with the Mud Pod as I fitted a flip out head unit which masked the switches. Made up some new wring loom extensions etc and also fitted the Disco hazzard switch. (and an oil temperature gauge)
Also fitted the Mudstuff single din holder assembly (passenger lower shelf) and then fitted a crafted switch frame assembly that allows fittment of 3 standard defender dash switches. (no phote atm)
Smile 2015 90 XS Santorini Black
Post #798035 14th Oct 2019 8:53am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I fitted the switch for my rear worklight in the steering column shroud. Pre-2014 models even had a blank hole there I believe
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #798104 14th Oct 2019 3:57pm
JOW240725
I had a sub-woofer box fitted below the cubby, primarily for somewhere to fit additional USB's for front and middle seat passengers. But it has a panel on front where you can fit a bank of extra switches.
 James
Instagram @suffolk_rovers
Post #798109 14th Oct 2019 4:15pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
Post #798228 15th Oct 2019 6:49am
Morepower
New Zealand
Where did you get the Heated Mirror switch from?
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #801662 10th Nov 2019 7:26pm
dorsetsmith
Post #801666 10th Nov 2019 7:53pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
I used a replacement drinks holder insert in the cubby box. Leaves a holder on the passenger side but has a cutout for 3 carling switches on the drivers side.
Bought it from one of the usual online retailers . Let me try and find a link...
Post #802026 13th Nov 2019 7:03am
Mike_E
https://www.paddockspares.com/cubby-box-ac...s-usb.html
A few options too like a 2 switch holder that retains both drink holders...
Post #802029 13th Nov 2019 7:09am
