Home > Td5 > Front seat swap over |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Interesting question, the most obvious problem would be the lever to adjust the seat back would be on the wrong side.
Seat belt receiver would be ok...try it! |
29th Sep 2019 7:02pm |
Dexterdog Member Since: 23 Jun 2018 Location: gloucestershire Posts: 108 |
Yes, I clocked the seat back lever but to be honest, it never gets moved once its set, so I thought that would be OK.
Guess I was being a bit lazy and asked before trying it in case someone has and the bracket bolts didnt line up or something. If no one posts with experience of trying this, I will give it a go and post an update on what happens |
29th Sep 2019 7:06pm |
I changed mine recently and from memory all 4 bolts are the same on each side.
29th Sep 2019 7:10pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 890 |
Bolt holes are identical 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
29th Sep 2019 8:12pm |
Thanks
29th Sep 2019 8:41pm |
For anyone who is thinking of this, it works fine. The recline lever for the seat is a bit tight but as long as you are not adjusting it all the time its ok to live with. Seat is lots more comfortable !
30th Sep 2019 6:00pm |
