Home > Td5 > Front seat swap over
Dexterdog
Hi,
Have had a search but cannot find any info on this.
I have a TD5 commercial, 2001. Drivers seat is knackered (back and base) but passenger one is almost unused.
Base is of course and easy swap but does anyone know if the front seats are interchangeable so I can swap the upright section (which I guess means the whole frame) over as well ?
Thanks
Post #795869 29th Sep 2019 7:57pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Interesting question, the most obvious problem would be the lever to adjust the seat back would be on the wrong side.
Seat belt receiver would be ok...try it!
Post #795873 29th Sep 2019 8:02pm
Dexterdog
Yes, I clocked the seat back lever but to be honest, it never gets moved once its set, so I thought that would be OK.
Guess I was being a bit lazy and asked before trying it in case someone has and the bracket bolts didnt line up or something.
If no one posts with experience of trying this, I will give it a go and post an update on what happens
Post #795875 29th Sep 2019 8:06pm
Tommo
I changed mine recently and from memory all 4 bolts are the same on each side.
Post #795880 29th Sep 2019 8:10pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Bolt holes are identical Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #795891 29th Sep 2019 9:12pm
Dexterdog
Thanks
Post #795915 29th Sep 2019 9:41pm
Dexterdog
For anyone who is thinking of this, it works fine. The recline lever for the seat is a bit tight but as long as you are not adjusting it all the time its ok to live with. Seat is lots more comfortable !
Post #796053 30th Sep 2019 7:00pm
