![]() | Home > Off Topic > Any Apple Mac IT experts? |
NJSS Member Since: 26 Aug 2014 Location: Catherington Posts: 31 ![]() ![]() |
I gave up on Apple kit some years ago due to problems of this nature.
I learnt were that one doesn't need Anti-Virus software or so-called “cleaning” apps. They are not recommended for Mac OS, as they can conflict with Mac's own built-in security, and they will slow your Mac by using unnecessary resources. You might download and run EtreCheck from https://etrecheck.com or https://download.cnet.com/EtreCheck/3000-2094_4-75749747.html which will give you a heads up on possible problems. Note I am not a Mac expert, others may well not agree with the above ![]() Good luck. NJSS 2016 Discovery 4 Landmark 2011 Mercedes Benz SL350 (R230) 1973 MG B GT V8 - 3.9L John Eales engine, 5 speed R380 gearbox, since 1975. 1959 MGA roadster - 1.9L Peter Burgess Engine - 5 speed gearbox Past LRs - Multiple FFRs, Discos & a Series I - some petrol, some diesel, none Electric yet. There are 10 types of people in this world: Those who understand binary, and those who don’t. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026 ![]() ![]() ![]() |
Apple kit is great, your start up time should be seconds so there’s something not quite right, have you tried restoring from a recent back up? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 124 ![]() ![]() ![]() |
As much RAM as possible and an SSD hard drive should make a big difference, assuming there are no other issues. Both are relatively cheap and further details here: https://guides.crucial.com/c/Mac_Mini_Late_2012
AV wise I use Sophos free and no issues: https://home.sophos.com/en-us/download-mac-anti-virus.aspx Last edited by newton-tony on 29th Sep 2019 9:19am. Edited 1 time in total |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
Thanks I might give that a try, I don’t have any antivirus software, although I did used to have a subscription to a cleaner programme which I no longer have. However, I got that after these problems were already there in an effort to try and fix it. 2007 110 TDCi Station Wagon XS |
The problems have been getting worse for long time so how far should I go back? I have Time Machine, but I don’t actually know how to restore from it without losing anything I’ve added recently. 2007 110 TDCi Station Wagon XS |
I’ve already doubled the RAM and it made zero difference. I’m not keen on blowing more money on an SSD when it’s current performance is so bad there must be some other underlying problem I think. 2007 110 TDCi Station Wagon XS |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2269 ![]() ![]() ![]() |
Certainly with other 'old' Apple stuff it seems that more modern updates can actually have a detrimental affect.........
?? Might be worth restoring to an older operating system?? |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I had a macbook pro with exactly the same symptons.
Took it to Apple fearing the harddrive/ram/processor was damaged or soemthing serious was wrong. They did a load of hardware tests and all was ok. What they told me was that as it's done so many software upgrades it's basically a software mess. I backed it up to Icloud. (really easy). Restored it as a new laptop (Not time machine that puts all the knackered software back on it). and it's now working brilliantly. Before you do ANYTHING. just back your data up. (2 minutes to set up) and restore it as new. Should solve your peoblem as it's exactly what happened to mine. ![]() PCM |
I’d be happy if I could do a fresh start and back up my data. All my photos are on external hdd, so they are fine whatever happens. Is there some instruction for doing it anywhere. I’m not familiar with iCloud 2007 110 TDCi Station Wagon XS
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
An SSD will certainly sort your issues out! I was having similar problems recently with my MacBook Pro 2011. New RAM and an SSD and its sorted, included in that was a fresh start with software though. so complete re-format and start again. Laptop is faster than it ever was even when new. So much so that I've sold my iMac and now just use my laptop with a separate monitor when home. Also means that I have all my software in one place and is easily transported wherever I go. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Backup is really easy.
You can check on icloud.com to see all your data is actually there. May take a few hours though for the first backup. The others are incremental and happen in the background. Instructions below: https://support.apple.com/en-us/HT208682 |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
If it scares you or you aren’t confident to do it yourself you can always visit one of the “geek” sessions at an Apple store for help too. They have very high speed WiFi in store if your home speed isn’t great. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
I just absolutely do not want to accidentally lose my photos and videos. There’s nothing else that is that important. 2007 110 TDCi Station Wagon XS
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I run a stack of Mac Minis from 2012 and earlier simply because they are good, solid and reliable hardware and will run any software you want. Mac, Windows or Linux.
The first thing I always do is max the RAM out and replace the hard disk with an SSD - the latter usually offers a massive performance increase, especially with boot times. It's always worth starting from scratch if you can. If your Apple ID is set up with iCloud then all your settings, passwords, photos and documents can automatically be synched BUT that does normally mean using a paid iCloud subscription as you only get 5GB for free. If you use iPhoto to store your images it's worth exporting them all for backup, they can then be imported into iPhotos on your new system. I would get an external USB hard drive and use Carbon Copy Cloner to completely back up your existing hard disk. Swap out the hard disk for an SSD then copy your photos etc... back from the USB drive. Your original Hard Disk is an additional backup of your data then and is untouched and can be put back in if it all goes horribly wrong ! With Carbon Copy Cloner you will also be able to boot from the external USB if you find you're missing something. If you're unsure about the above, find someone who can do it for you. Changing the hard disk in a Mac Mini can be quite daunting the first time and you may need to get some tools (Torx head screws hold most of it together). There are online guides available that will take you through it step by step. http://www.yorkshireoffroadclub.net/ |
