Home > Technical > Would you change the oils etc after 500 miles ?
razz
2001 Defender 90 Td5 PU Caledonian Blue
Hello everyone , it’s been a year already since I did a full service on the pit machine , she’s done around 500 pit miles since then , the magnetec engine oil , axle oils , still look like new , not looked in the gearboxes , should I treat her to all new oils n filters or give it another few pit runs would you say ?
Post #795473 27th Sep 2019 5:22pm
Pilgrimmick
If water is not getting in then leave it till the service interval. Less work to do for the oils at low speed than on the motorway. 6000 miles should be fine. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #795475 27th Sep 2019 5:33pm
jst
Pit runs? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #795522 27th Sep 2019 8:26pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Yes I would, easy to do, and relatively cheap. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #795554 28th Sep 2019 6:14am
lohr500
I would definitely change the engine oil and filter.
On the gearbox/transfer case/axles, I would wizz out the filling plugs to check the levels and to look for any signs of oil emulsification. If levels OK and no creamy coloured oil, then I would leave alone and change next year.
Post #795556 28th Sep 2019 6:37am
razz
jst wrote:
Pit runs?
hello there , i only use mine around a pit , hence the pit runs , but she is road legal so i can get her there Thumbs Up
Post #795598 28th Sep 2019 12:41pm
razz
thanks everyone , i`ll do another pit visit , then i`ll stagger the changes over winter Thumbs Up
Post #795599 28th Sep 2019 12:42pm
90 Dreamer
i think people aren't familiar with your 'pit' wording............guess you mean an old quarry or whatever where you can "play"
Post #795611 28th Sep 2019 2:09pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
I would have thought the photo was self-explanatory.
Post #795613 28th Sep 2019 2:12pm
oneten110
Yes change all oils. Oil is cheap, engines, gearboxes etc are not It is not a Defender, it is a One_Ten
Post #795832 29th Sep 2019 5:36pm
