![]() | Home > Technical > Would you change the oils etc after 500 miles ? |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
If water is not getting in then leave it till the service interval. Less work to do for the oils at low speed than on the motorway. 6000 miles should be fine. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
Pit runs? Cheers
Bows Member Since: 07 May 2012 Location: Wales Posts: 525 ![]() ![]() ![]() |
Yes I would, easy to do, and relatively cheap. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
I would definitely change the engine oil and filter.
On the gearbox/transfer case/axles, I would wizz out the filling plugs to check the levels and to look for any signs of oil emulsification. If levels OK and no creamy coloured oil, then I would leave alone and change next year. |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
hello there , i only use mine around a pit , hence the pit runs , but she is road legal so i can get her there ![]() |
thanks everyone , i`ll do another pit visit , then i`ll stagger the changes over winter
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2288 ![]() ![]() ![]() |
i think people aren't familiar with your 'pit' wording............guess you mean an old quarry or whatever where you can "play"
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
I would have thought the photo was self-explanatory.
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Yes change all oils. Oil is cheap, engines, gearboxes etc are not It is not a Defender, it is a One_Ten
