![]() | Home > Td5 > Front interior door light wiring |
up the A pillar out just under wing in to engine bay
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Cheers. 1999 Defender TD5 110
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I dont know if it helps but one of mine was broken and wouldnt set off the alarm or interior light.
As a temporary repair I ran a wire from the door pin on the broken side up the A pillar and behind the dash top to the wire on the opposite side. End result is both doors operate the light and the alarm again. It was 3 yrs ago and it works so well I've left it. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Cheers for the tip - if it comes to that. 1999 Defender TD5 110
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 335 ![]() ![]() ![]() |
If it is the O/S front wire, it will probably go to the ECU.
Thanks. 1999 Defender TD5 110
AS10 alarm unit My1999 ![]() Click image to enlarge My 2002 ![]() Click image to enlarge My 2002 ![]() Click image to enlarge |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5348 ![]() ![]() |
has the switch gone on the bink or the light loom? I did buy a loom for my TDi for the rear, so its here gathering dust. ( just plugs into the loom on the roof) mine had rotted out badly The door switches you can rob off any rover. I robbed mine off my rover metro. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I need to do some mods. 1999 Defender TD5 110
The switches are not expensive if you need them. About £2 each if I remember right 2014 - current ..... 2003 defender td5 90 (my car)
Thanks Gazman 1999 Defender TD5 110
