![]() | Home > Td5 > Front interior door light wiring |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
up the A pillar out just under wing in to engine bay
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018
Cheers. 1999 Defender TD5 110
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
I dont know if it helps but one of mine was broken and wouldnt set off the alarm or interior light.
As a temporary repair I ran a wire from the door pin on the broken side up the A pillar and behind the dash top to the wire on the opposite side. End result is both doors operate the light and the alarm again. It was 3 yrs ago and it works so well I've left it. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Cheers for the tip - if it comes to that. 1999 Defender TD5 110
| SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 335
If it is the O/S front wire, it will probably go to the ECU.
Thanks. 1999 Defender TD5 110
AS10 alarm unit My1999 Click image to enlarge My 2002 Click image to enlarge My 2002 Click image to enlarge |
| Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347
has the switch gone on the bink or the light loom? I did buy a loom for my TDi for the rear, so its here gathering dust. ( just plugs into the loom on the roof) mine had rotted out badly The door switches you can rob off any rover. I robbed mine off my rover metro. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I need to do some mods. 1999 Defender TD5 110
The switches are not expensive if you need them. About £2 each if I remember right 2014 - current ..... 2003 defender td5 90 (my car)
Thanks Gazman 1999 Defender TD5 110
