![]() | Home > Technical > Air Conditioning TD5 - Blower Fan Intermittent |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Hello. I have the same system in my TD5, admittedly I barely ever used it. From what I understand the system is almost a carbon copy of the original LR item so in all likelihood the wiring diagram is going to be quite similar.
So the problem lies at the blower switch, the control relay, the wiring or in the blower motor itself. Have you done any checks to the switch and relay? Sounds a little like a intermittent connection issue to me. Have you contacted Coolair Logan yet to ask for advice? Have to confess my experience with them is not great, but that was years ago now and you may have more luck. |
| All times are GMT |
