![]() | Home > Puma (Tdci) > MIL Ligth on |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Yesterday the MIL ligth come up
![]() ![]() According to ny ODBII reading the EGR is not working properly ![]() ![]() ![]() I clean the failure to see if it is a false lecture. So later on we will see if the problem coming up again. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Im out of guarantee, so no problem with clean up the code.
Anyway will be with the dealers on Thursday for the parking brake recall and to change the clutch master cylinder. (I should prepare my pocket I think ![]() Error was P0401. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
P0401 Exhaust Gas Recirculation "A" Flow Insufficient Detected Yes, and you may need to dip the wifes pocket as well what with the dealers prices for labour ![]() |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
A great avater photo Eduardo
Update.
After clean the fault codes yesterday morning the MIL has not appeared again (As I was afraid), so probably was a false positive (I hope). The motor are running equal than before and the squecks when you turn off the engine are there. Thanks war pig for the comment, the photo was taken in the north of Chile near an astronomic observatory. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Eduardo,
Witch tool do you use to read the ODBII error code and clear it ? |
glad all seems ok Ed
![]() 1968 1/32 scale Britains 109 Pick up. |
MD5
Finally and after looking several alternatives I bought this cheap piece http://www.amazon.com/gp/product/B002PYBZJO The provided software can erase the error codes stored in the ECU. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thanks for the information, the device you use sound interesting and cheap but it need a connection with a laptop computer to run.
I prefer a sand alone device like the Scangauge2. |
Yep,
It is not standalone unit like Scangauge2 In my case do the work that I need: I only need to check the system in real time if something fails and always in long trips I have the laptop with me. If you are interested there is some ones that you can connect to a handheld (CE-windows or Android software needed) via bluetooth at almost the same cost. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Bad news
Ligth come up again yesterday night ![]() ![]() ![]() So today I will see if it is the same code and probably next week will be again with the dealers to solve it. All that after change the clutch master cylinder and make the recall the last week. I should love a lot this car ![]() ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
