Home > Puma (Tdci) > MIL Ligth on
Eduardo
MIL Ligth on
Yesterday the MIL ligth come up Evil or Very Mad Evil or Very Mad
According to ny ODBII reading the EGR is not working properly Evil or Very Mad Evil or Very Mad Evil or Very Mad
I clean the failure to see if it is a false lecture. So later on we will see if the problem coming up again.
Cheers Eduardo
Post #74323 5th Jun 2011 5:43pm
Lorryman100
Hi Ed, the fact that the MIL light came on shows it's a tested DTC and should only be reset if you are out of warranty as tested dtc's are required for a claim using IDS at the dealers. What code did you receive? Does the self clean cycle run when you switch off, 5 pukka pukkas? Any change in the engine when running at idle, ie rougher or smoother or no change? If it was stuck closed I would ignore it and revel in the better mpg, if it was stuck open I would be looking to get it rectified soon as Thumbs Up
Post #74324 5th Jun 2011 5:49pm
Eduardo
Im out of guarantee, so no problem with clean up the code.
Anyway will be with the dealers on Thursday for the parking brake recall and to change the clutch master cylinder. (I should prepare my pocket I think Crying or Very sad )
Error was P0401.
Cheers Eduardo
Post #74327 5th Jun 2011 5:58pm
Lorryman100
Error was P0401.
P0401 Exhaust Gas Recirculation "A" Flow Insufficient Detected
Yes, and you may need to dip the wifes pocket as well what with the dealers prices for labour Evil or Very Mad
Post #74329 5th Jun 2011 6:04pm
WarPig
A great avater photo Eduardo Thumbs Up
Post #74347 5th Jun 2011 7:58pm
Eduardo
Update.
After clean the fault codes yesterday morning the MIL has not appeared again (As I was afraid), so probably was a false positive (I hope).
The motor are running equal than before and the squecks when you turn off the engine are there.
Thanks war pig for the comment, the photo was taken in the north of Chile near an astronomic observatory.
Cheers! Eduardo
Post #74505 6th Jun 2011 7:29pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Eduardo,
Witch tool do you use to read the ODBII error code and clear it ?
Post #74533 6th Jun 2011 9:15pm
Grockle
glad all seems ok Ed Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #74596 7th Jun 2011 8:15am
Eduardo
MD5
Finally and after looking several alternatives I bought this cheap piece
http://www.amazon.com/gp/product/B002PYBZJO
The provided software can erase the error codes stored in the ECU.
Cheers Eduardo
Post #74607 7th Jun 2011 9:20am
MD5
Thanks for the information, the device you use sound interesting and cheap but it need a connection with a laptop computer to run.
I prefer a sand alone device like the Scangauge2.
Post #74703 7th Jun 2011 7:58pm
Eduardo
Yep,
It is not standalone unit like Scangauge2
In my case do the work that I need: I only need to check the system in real time if something fails and always in long trips I have the laptop with me.
If you are interested there is some ones that you can connect to a handheld (CE-windows or Android software needed) via bluetooth at almost the same cost.
Cheers Eduardo
Post #74730 7th Jun 2011 9:25pm
Eduardo
Update
Bad news
Ligth come up again yesterday night Sad Sad Sad
So today I will see if it is the same code and probably next week will be again with the dealers to solve it.
All that after change the clutch master cylinder and make the recall the last week.
I should love a lot this car Mr. Green Mr. Green Eduardo
Post #76985 21st Jun 2011 2:42pm
