Home > Maintenance & Modifications > Tdi sump plug size
spudfan
Ireland
Tdi sump plug size
What size socket fits the sump plug on a 200 tdi 1992? It is bigger than 27mm and smaller than 30mm. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #788106 21st Aug 2019 9:06pm
NickMc
It’s imperial but a 29mm will work.
Post #788124 21st Aug 2019 9:49pm
spudfan
Ireland
Thank you. I have been using an adjustable wrench and would like to be able to use a socket instead. 1982 88" 2.25 diesel
Post #788127 21st Aug 2019 9:55pm
NickMc
I’m a metric man so you’ll have to work out what that is in inches yourself Laughing
Post #788151 22nd Aug 2019 12:17am
The actual measurement is a fraction over 29mm and last time I did one I used a 30mm socket. Darren
Post #788169 22nd Aug 2019 7:28am
In that case it is probably 1.1/8" AF, which in metric terms is 28.575mm.
In that case it is a hybrid size since there is no imperial size that corresponds.
1.1/8" AF is smaller at 28.575mm AF
5/8" BSW 11/16" BSF is smaller at 27.94mm AF
1.3/16" AF (highly unusual) is larger at 30.1625mm AF (although a 30mm socket would probably fit)
11/16" BSW (very rare) 3/4" BSF is larger at 30.48mm AF
Since I don't have one to investigate, my money's on NickMc with his 1.1/8" AF ! Thumbs Up
Post #788193 22nd Aug 2019 9:27am
spudfan
Ireland
Thank you all. It is a bit like too much information!!! Last time I used a 30 mm socket it was slack and I was afraid it would round the edges of the sump plug. Last night I went on Ebay and ordered a 29mm socket. I know any normal person going on the internet at night usually checks out the "educational" stuff, but after all I am a Land Rover owner so what else do you expect.
Must go on now and search for a 1.1/8" AF socket. I do have AF sockets aswell as mm type but not that size. It is always the same.... it is always the tool you do not have that you need!!!
Once again many thanks. 1982 88" 2.25 diesel
Post #788215 22nd Aug 2019 10:58am
spudfan
Ireland
Update. Just been online and ordered the 1.1/8" AF socket. This is so exciting. To cap it all tonight is the anniversary of our first date all of those years ago. Can't wait to see the wife's face when I gift wrap the 29mm socket and the 1.1/8" AF socket when they arrive Mr. Green Who says romance is dead? 1982 88" 2.25 diesel
Post #788217 22nd Aug 2019 11:08am
^^^ It's happening! Shocked There's no going back now.
Post #788234 22nd Aug 2019 1:10pm
spudfan
Ireland
I got my two sockets today. The 29mm will do the trick but the imperial 1.1/8" AF socket is a perfect fit. So if you need one for the sump of your 200 tdi you should be able to get one or the other.
Once again many thanks for the info. 1982 88" 2.25 diesel
Post #788960 27th Aug 2019 9:22pm
