Home > Puma (Tdci) > REB500200 REB500220 Puma front coil spring rates
Rickoz
Australia 2014 Defender 90 Puma 2.2 SW Keswick Green
Hello all, I done a search here and everywhere looking for the Load and Load Rating of the REB500200 / REB500220 Puma Defender front springs but all I seem to find is the same basic info copied on every Forum.
I’ve found the colour coding and free length, they are - (200) Red/Green/White 370mm and (220) Red/Green/Orange 380mm
This info is easily available for the older springs eg:
NRC9446 Blue/Green 15.19” Load Rating 175lb/inch (load 819.96lb)
NRC9447 Blue/Yellow 14.80” Load Rating 175lb/inch (load 819.98lb)
Anyone know or can point to a link which the Load Rating lb/” and (Load lb) at all?
Regards, Rickoz.
Post #787984 21st Aug 2019 4:14am
Naks
Rickoz, are these new part numbers not just superceding the old ones?
that is, isn't REB500220 just the new part number for NRC9446?
I'm sure you've seen this site, with the various part number and info? http://red90.ca/rovers/springinfo.html --
Post #787989 21st Aug 2019 6:24am
Rickoz
Sorry I don’t know I did think this could be the case for half a second but why change the model numbers & colour codes.
I have just counted the coil numbers & the NRC’s are 7.75 coils & the REB’s seem to be 7.00 If I’ve counted correctly.
Post #787994 21st Aug 2019 7:37am
CarMan
Guessing you've seen this:
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #787998 21st Aug 2019 8:09am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
https://www.defender2.net/forum/topic68749.html
I put a link in this thread where a similar table to the above states all the spring rates etc.
Post #788001 21st Aug 2019 8:22am
Rickoz
Yep that the info that everyone reposts but that doesn’t tell us the lb/inch or the Load
Post #788015 21st Aug 2019 10:37am
Bluest
This table has spring rates in it. Any good? http://red90.ca/rovers/springinfo.html 2007 110 TDCi Station Wagon XS
Post #788019 21st Aug 2019 11:15am
The table on the red90 site that crops up a lot is, unfortunately, quite old. As such, it doesn't cover the newer spring markings and ratings of Puma-era vehicles. Darren
Post #788052 21st Aug 2019 4:42pm
Naks
indeed, and none of the online shops list that info either.
Neither does the workshop manual, and I doubt the dealers will even understand the question Rolling Eyes --
Post #788194 22nd Aug 2019 9:28am
Rickoz
I guess it can be worked out buy the compressed height of the springs if someone measures there STD Puma with no accessories added to there 4B
As far as I know the free lengths are D/side 370mm & P/side 380mm (RHD)
Post #788664 26th Aug 2019 12:39pm
