![]() | Home > Puma (Tdci) > REB500200 REB500220 Puma front coil spring rates |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Rickoz, are these new part numbers not just superceding the old ones?
that is, isn't REB500220 just the new part number for NRC9446? I'm sure you've seen this site, with the various part number and info? http://red90.ca/rovers/springinfo.html -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Rickoz Member Since: 27 Jan 2014 Location: 4000 Posts: 39 ![]() ![]() ![]() |
Sorry I don’t know I did think this could be the case for half a second but why change the model numbers & colour codes.
I have just counted the coil numbers & the NRC’s are 7.75 coils & the REB’s seem to be 7.00 If I’ve counted correctly. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1891 ![]() ![]() |
Guessing you've seen this:
![]() Click image to enlarge Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic68749.html
I put a link in this thread where a similar table to the above states all the spring rates etc. |
Yep that the info that everyone reposts but that doesn’t tell us the lb/inch or the Load |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
This table has spring rates in it. Any good? http://red90.ca/rovers/springinfo.html 2007 110 TDCi Station Wagon XS
The table on the red90 site that crops up a lot is, unfortunately, quite old. As such, it doesn't cover the newer spring markings and ratings of Puma-era vehicles. Darren
indeed, and none of the online shops list that info either. Neither does the workshop manual, and I doubt the dealers will even understand the question ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I guess it can be worked out buy the compressed height of the springs if someone measures there STD Puma with no accessories added to there 4B
As far as I know the free lengths are D/side 370mm & P/side 380mm (RHD) |
