![]() | Home > Technical > Puma 130 - Rear Diff Questions |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
The diff should be sealed into the axle with Hylosil 100.
On the P38 diff, the genuine tool sets the seal 1.6mm into the pinion housing (on tne Rover pattern diff the seal is set 6.0mm into the housing). |
| Big Monkey Member Since: 11 Sep 2018 Location: North East Scotland Posts: 8
Hi Blackwolf,
Thanks for the reply. I'll get some Hylosil. I'll turn up a tool to set the seal 1.6mm into the housing, as I assume I have the P38 style diff? If it's not a dumb question, which Land Rover has the Rover pattern diff? Cheers, Darren. |
For Tdci and late Td5, Rover pattern diff front and rear on 90, front only on both 110 and 130. P38 diff in rear on 110 and 130.
I don't think the 1.6mm will be a problem, I'd leave it as it is. |
Thanks again of the reply. Right, I'll leave as is and get on with putting the rest of it back together.
| sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250
Since it's all out. Something you may want to consider is a "Super flange" from Nige at Xcess4x4, it's been machined to sit much closer to the pinion housing and protects the seal very well. Used to trash a seal about once a year with the use I gave it but not had an issue since fitting those. Mind you with two pegged Ashlockers in situ I wanted to protect my investment and it wasn't a whole lot in the grand scheme of things. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
| oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741
Didn't Land Rover offer a flange with a mudshield for the rear differential?
https://www.brit-car.co.uk/product.php/928...__defender It is not a Defender, it is a One_Ten |
They all used to have mudshields until they were "value engineered" out!
Have you seen the price of that flange in the link above? It's £180 including they vat, I nearly spilt my tea! |
Make's Nige's a bargain - think it was about the £100 mark Ed
| Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271
Had one fitted to my 4 pin, fantastic piece of kit
Click image to enlarge |
Sadly for information only because it is for the earlier Dana 60 axle. Pity they didn't do something similar for the later axles.
https://www.brit-car.co.uk/product.php/246...__wa159806 It is not a Defender, it is a One_Ten |
Again Nige's flange will fit the newer axles. My rear is certainly a P38 / Wolf diff off a late Td5 110 so the same I think as the Tdci where it matters. Ed
| All times are GMT |
