Home > Technical > Puma 130 - Rear Diff Questions
Big Monkey
United Kingdom 1985 Defender 110 300 Tdi HT Galway Green
Hi Folks,
I've just replaced the diff pinion seal on my rear axle. I have the complete axle out on the bench, I didn't have the special tool, so pushed the seal down so that it was flush with the top of the nose of the diff. Is this the right thing to do?
Also, there was no diff gasket, so I assume that I just use silicone to seal the diff casting to the axle housing?
Cheers,
Darren.
Post #787033 15th Aug 2019 5:27pm
The diff should be sealed into the axle with Hylosil 100.
On the P38 diff, the genuine tool sets the seal 1.6mm into the pinion housing (on tne Rover pattern diff the seal is set 6.0mm into the housing).
Post #787082 15th Aug 2019 8:25pm
Big Monkey
Hi Blackwolf,
Thanks for the reply.
I'll get some Hylosil.
I'll turn up a tool to set the seal 1.6mm into the housing, as I assume I have the P38 style diff?
If it's not a dumb question, which Land Rover has the Rover pattern diff?
Cheers,
Darren.
Post #787089 15th Aug 2019 8:56pm
For Tdci and late Td5, Rover pattern diff front and rear on 90, front only on both 110 and 130. P38 diff in rear on 110 and 130.
I don't think the 1.6mm will be a problem, I'd leave it as it is.
Post #787105 15th Aug 2019 9:58pm
Big Monkey
Thanks again of the reply. Right, I'll leave as is and get on with putting the rest of it back together.
Post #787132 16th Aug 2019 6:40am
sako243
Since it's all out. Something you may want to consider is a "Super flange" from Nige at Xcess4x4, it's been machined to sit much closer to the pinion housing and protects the seal very well. Used to trash a seal about once a year with the use I gave it but not had an issue since fitting those. Mind you with two pegged Ashlockers in situ I wanted to protect my investment and it wasn't a whole lot in the grand scheme of things. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #788448 24th Aug 2019 7:51am
oneten110
Didn't Land Rover offer a flange with a mudshield for the rear differential?
https://www.brit-car.co.uk/product.php/928...__defender It is not a Defender, it is a One_Ten
Post #789358 29th Aug 2019 4:41pm
They all used to have mudshields until they were "value engineered" out!
Have you seen the price of that flange in the link above? It's £180 including they vat, I nearly spilt my tea! Shocked
Post #789370 29th Aug 2019 6:09pm
sako243
Make's Nige's a bargain - think it was about the £100 mark Ed
Post #789382 29th Aug 2019 7:39pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Had one fitted to my 4 pin, fantastic piece of kit
Post #789393 29th Aug 2019 8:46pm
oneten110
Sadly for information only because it is for the earlier Dana 60 axle. Pity they didn't do something similar for the later axles.
https://www.brit-car.co.uk/product.php/246...__wa159806 It is not a Defender, it is a One_Ten
Post #789508 30th Aug 2019 12:51pm
sako243
Again Nige's flange will fit the newer axles. My rear is certainly a P38 / Wolf diff off a late Td5 110 so the same I think as the Tdci where it matters. Ed
Post #789574 30th Aug 2019 3:51pm
