Home > Puma (Tdci) > Light Buzzer |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
I have that on my 2015 tdci as standard so JLR must do it as an available part?
I wish the indicators either cancelled better or had an audio-able warning 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
9th Aug 2019 4:10pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
Ok interesting. Mine is a 2010 2.4.
Does anyone have a wiring diagram showing how they did it or know the part number? |
9th Aug 2019 4:30pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6477 |
It's built into the instrument pack on 2015MY+.
Door open + lights on = bing bing bing 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Aug 2019 4:40pm |
Thanks Martin 2015 HT XS 90
9th Aug 2019 4:46pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3333 |
Mine has the hard of hearing version to stop you leaving your lights on.
The light switch is so positioned that it makes removal of the ignition key kind of impossible, without turning the lights out I have often wondered why JLR put any effort at all into adding 'extras' or subtle changes to the defenders on the 2015 and newer ones. Like why did they change the splines of the steering wheel. Why did they change the colour of the roof lining? Is there also a spare switch to turn the traction control off? Why did they bother? I'm sure there is a reason, but I haven't a clue |
9th Aug 2019 5:29pm |
Bits left over in the spare parts section after McGovern had a brain fart perhaps? 2015 HT XS 90
9th Aug 2019 6:21pm |
Brain fart. That's twice I have read that today. Must write that down for use latter
You see what I have always thought. An unloved, low volume vehicle that was at the end of its run. I understand bling a high volume car to get shot of the older version just before the new one was released, but they didn't even have a new model to sell? If I had been holding the purse strings, I think I would have just kept pumping them out of Lode Lane with the least effort possible. |
9th Aug 2019 6:36pm |
They invested a few million quid in the updated DSC system (the reason for the traction control button). 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Aug 2019 9:24pm |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 227 |
Any advice on how to do this as Iād like it too! 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
9th Aug 2019 9:31pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
Have a look at:
http://defender90xs.blogspot.com/2014/03/l...uzzer.html Or as a simpler install it is possible to pick up the side light and ignition circuits from the rear of the cigarette socket in the dash and connect up one of these: https://www.autoelectricsupplies.co.uk/product/264/category/53 Keith Keith |
9th Aug 2019 9:34pm |
Get a 12V buzzer. Loudness/annoyance level of your choice
Positive to the dash illumination - easiest behind a switch/cig lighter. Colour is RED with ORANGE stripe. Negative to the driver's door switch. Colour is GREY with WHITE stripe. Either remove the screw and carefully remove the switch from the driver's door shut and splice into the wire (or even better make a proper male+female Y cable), or find it at the alarm ECU grey connector pin 5. If you need terminals, female/male locking spades, retrofit quality splice connectors etc drop me a PM 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Aug 2019 9:37pm |
