Home > Puma (Tdci) > Light Buzzer
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Light Buzzer
Has anyone fitted a buzzer so that if you leave the lights on with the ignition off it buzzes?
Thought it would be fairly simple but struggling.
If anyone has which specific buzzer did you use?
Thanks šŸ™
Post #785891 9th Aug 2019 4:03pm
Sulisuli
I have that on my 2015 tdci as standard so JLR must do it as an available part?
I wish the indicators either cancelled better or had an audio-able warning Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #785895 9th Aug 2019 4:10pm
boxoftricks
Ok interesting. Mine is a 2010 2.4.
Does anyone have a wiring diagram showing how they did it or know the part number?
Post #785903 9th Aug 2019 4:30pm
Martin
Site Admin
It's built into the instrument pack on 2015MY+.
Door open + lights on = bing bing bing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #785904 9th Aug 2019 4:40pm
Sulisuli
Thanks Martin Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #785908 9th Aug 2019 4:46pm
Rashers
Mine has the hard of hearing version to stop you leaving your lights on.
The light switch is so positioned that it makes removal of the ignition key kind of impossible, without turning the lights out
Thumbs Up
I have often wondered why JLR put any effort at all into adding 'extras' or subtle changes to the defenders on the 2015 and newer ones. Like why did they change the splines of the steering wheel. Why did they change the colour of the roof lining? Is there also a spare switch to turn the traction control off? Why did they bother?
I'm sure there is a reason, but I haven't a clue Shocked
Post #785922 9th Aug 2019 5:29pm
Sulisuli
Bits left over in the spare parts section after McGovern had a brain fart perhaps? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #785944 9th Aug 2019 6:21pm
Rashers
Brain fart. That's twice I have read that today. Must write that down for use latter Laughing
You see what I have always thought. An unloved, low volume vehicle that was at the end of its run. I understand bling a high volume car to get shot of the older version just before the new one was released, but they didn't even have a new model to sell?
If I had been holding the purse strings, I think I would have just kept pumping them out of Lode Lane with the least effort possible.
Post #785948 9th Aug 2019 6:36pm
Martin
Site Admin
They invested a few million quid in the updated DSC system (the reason for the traction control button).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #786007 9th Aug 2019 9:24pm
Minch90
Any advice on how to do this as I’d like it too! 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #786009 9th Aug 2019 9:31pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Have a look at:
http://defender90xs.blogspot.com/2014/03/l...uzzer.html
Or as a simpler install it is possible to pick up the side light and ignition circuits from the rear of the cigarette socket in the dash and connect up one of these: https://www.autoelectricsupplies.co.uk/product/264/category/53
Keith Keith
Post #786010 9th Aug 2019 9:34pm
Martin
Site Admin
Get a 12V buzzer. Loudness/annoyance level of your choice Laughing
Positive to the dash illumination - easiest behind a switch/cig lighter. Colour is RED with ORANGE stripe.
Negative to the driver's door switch. Colour is GREY with WHITE stripe. Either remove the screw and carefully remove the switch from the driver's door shut and splice into the wire (or even better make a proper male+female Y cable), or find it at the alarm ECU grey connector pin 5.
If you need terminals, female/male locking spades, retrofit quality splice connectors etc drop me a PM Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #786013 9th Aug 2019 9:37pm
