Home > Maintenance & Modifications > Sticking calliper |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
Damage to a brake pipe could cause the caliper to stick - if, for example, it has been flattened by an impact to create a restriction which means that fluid can be forced through under pedal pressure but not back again - or, if you have ABS, it is possible that an ABS fault could cause this.
There is no other obvious reason why successive calipers in the same position on the car should fail repeatedly. |
9th Aug 2019 9:00am |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
Brake pads could be seized in their slider. That does happen sometimes
9th Aug 2019 9:14am |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
It’s non ABS on a 2004 Td5. I’ll have a good look under to see if anything looks damaged but I don’t think it’s ever been off road, abused or damaged. Maybe it’s just my usual luck returning Thanks for your replies.
9th Aug 2019 11:36am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5422 |
What make of calliper was fitted?
Pop it off and check for rust/pitting on the piston. If it is then I can’t see it can be anything else other than bad luck, or cheap parts. |
9th Aug 2019 12:22pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
How many miles did the first one last and how many miles has this one been on, over what time period? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Aug 2019 7:06pm |
First one was on it when I bought it so no idea how long it had been on but I ran with it for maybe 3 years? Second one has lasted about 18 months and probably about 8 thousand miles. The replacement was the same ‘make’ as the one that came off, but came from a motor factor who wanted my old unit as a return so it was likely a refurbished unit.
Is it a case that some will be refurbished better than others, and if so how can you tell when buying? |
9th Aug 2019 7:33pm |
8k miles over 18mths suggests a bigger issue than just a problem caliper. as above looks for causes for it to fail. squashed hose as mentioned most likely. replacing the caliper will fix it for now but it will come back around. Cheers
9th Aug 2019 7:46pm |
