![]() | Home > Maintenance & Modifications > Airtronic D2 diesel heater install |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Did a little more tonight, planned the location of the heater. Its going under the passenger side rear seat. Started drilling the mounting holes but my hole saw packed in
![]() Regards John M0VAZ Econet Station 48 no clock |
While waiting for some more fuel pipe to appear, I finished off the fuel tank install. Mounted as shown above, and then fuel pump mounted on the inner wing by the engine air filter inlet pipe.
There is also a small filter before the pump as well. Decided to mount the 801 controller here: ![]() Click image to enlarge Now I need to extend the wiring to from the 801 to the main heater loom and extend the wires for the fuel pump supply. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Tidied up the wires for the diesel heater control panel and replaced the heater loom cables joined with choc blocks with Econseal multi plug.
Exhaust wrap and exhaust clamps arrived, so next job there is to secure the exhaust with a bracket and wrap in insulation. The final wiring step is to add a 70amp relay to feed the heater switched via a carling switch on the dash. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
