![]() | Home > Technical > 13pin Towing Socket |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Should be P&P if you buy the original LR harness....
https://www.defender2.net/gallery/albums/u...agrams.pdf Here the schematics and the connector C0718 is present on the car (rear RH wheelarc, under the splash guard, same as the lower rear RH lights) Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308
perfect, thats what i was hoping
thank you |
| DG123 Member Since: 29 Aug 2015 Location: North West Posts: 143
Hi - plug-in for 13 pin electrics only goes as far a lights/indicators. It gives you the equivalent of the black 12N 7 pin plug. The rest of the electrics (i.e. the functionality of the old 7-pin 12S connector) including permanent and switched lives, split charge relay and reversing light takes a bit more faffing.
Click image to enlarge Click image to enlarge It’s all well documented in the genuine LR electrics fitting kit, and many have taken the feeds for these from the rear of the vehicle. I still haven’t got around to fitting the ‘12S’ part of mine. The genuine kit LR005919 for a 2012 Puma has a really well sealed 13 pin plug that hasn’t given any issues compared to other vehicles that have had generic ones fitted by local tow bar places FWIW I fitted the 13 pin socket in the rear crossmember (with rivinuts). It’s then only a few bolts to take off the towbar and the electrics stay put. Also less chance of damage. Good luck 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
Cheers for the extra info, have just done the relay / extra wiring on a different vehicle so not phased by that side
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
Only the ignition feed for the socket is a “faff” involving the relay. Everything else is done by plugging in.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| All times are GMT |
