Home > Technical > 13pin Towing Socket
90 Dreamer
13pin Towing Socket
newly purchased 2016 Defender 90 has never had a tow bar on any electrics installed from new..........
do they have any 'easy install' on board wiring to install a plug N play harness to or is it a case of the old school piggy back wiring???
will need to install the newer style 13pin EU type socket due to towing requirements
Post #784661 3rd Aug 2019 1:59pm
dgardel
Italy
Should be P&P if you buy the original LR harness....
https://www.defender2.net/gallery/albums/u...agrams.pdf
Here the schematics and the connector C0718 is present on the car (rear RH wheelarc, under the splash guard, same as the lower rear RH lights)
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #784663 3rd Aug 2019 2:35pm
90 Dreamer
perfect, thats what i was hoping
thank you
Post #784671 3rd Aug 2019 3:30pm
DG123
Hi - plug-in for 13 pin electrics only goes as far a lights/indicators. It gives you the equivalent of the black 12N 7 pin plug. The rest of the electrics (i.e. the functionality of the old 7-pin 12S connector) including permanent and switched lives, split charge relay and reversing light takes a bit more faffing.
It’s all well documented in the genuine LR electrics fitting kit, and many have taken the feeds for these from the rear of the vehicle. I still haven’t got around to fitting the ‘12S’ part of mine.
The genuine kit LR005919 for a 2012 Puma has a really well sealed 13 pin plug that hasn’t given any issues compared to other vehicles that have had generic ones fitted by local tow bar places
FWIW I fitted the 13 pin socket in the rear crossmember (with rivinuts). It’s then only a few bolts to take off the towbar and the electrics stay put. Also less chance of damage.
Good luck 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #784855 4th Aug 2019 3:28pm
90 Dreamer
Cheers for the extra info, have just done the relay / extra wiring on a different vehicle so not phased by that side
Post #784856 4th Aug 2019 3:34pm
Martin
Site Admin
Only the ignition feed for the socket is a “faff” involving the relay. Everything else is done by plugging in.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #784860 4th Aug 2019 4:24pm
