![]() | Home > Maintenance & Modifications > Difficult to fill tank |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Tried a different pump/station? I find some pumps are really twitchy and click off when filling the Defender. Different angle usually does it, or pulling out slightly.
(Stop sniggering you lot) |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Story of my life miker, pull out and try a different angle
![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3633 ![]() ![]() ![]() |
![]() ![]() ![]() Between the sniggering, I would try a different filling station if possible. I find the Defender fills better if I just pull the nozzle out a little. Saying all that, I have to listen for the tank to fill. It changes tone as it gets full and if I forget it usually spits diesel all over the forecourt and me if I am unlucky. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
I’m glad I’m not the only one then! I’ve had it before and pulling out slightly or changing angle helped. Now I have to pull out and slow down the flow rate
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
The trigger on the end of the pump start to wear and cannot hold the spring mech back so they click off for this reason.
It happens with my local garage, just try another pump next time. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Not with the Defender, but my last Ford Focus company car (62 Plate) was an absolute nightmare when our local Sainsbury's installed new pumps. It was so bad, I tried to fill up at another Sainsbury's (I was, at the time collecting Nectar points).
There is obviously something they can do to remedy this problem as others were moaning and after about six weeks, the pumps were fine. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Slightly off topic, I recently used a HGV pump
OK seems like it’s down to dodgy pumps then! Thanks for the assistance chaps! I’ll try a non-supermarket station tomorrow and report back! Charlie
Solved the problem the other day! Turned out that the new vent hose had rather a significant kink in it. Just pulled it straight and all is fine now! Charlie
