Home > Off Topic > Dremel decided to try and quit....
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Hi,
Been giving the dremel a hammering and it decided to get very hot and have a little smoke.
Now, if I turn it on it runs very slowly and immediately gets hot and starts to smoke again.
Having seen you can buy all the parts online, I stripped it down. Everything looks fine inside on the boards, the only thing I have spotted is this tiny burn;
Is this a sign that one of the windings has a short and has cooked it self?
I can replace the part in the picture above, but it’s the most expensive part on the list, so just wanted a second opinion before I clicked buy.
Yan
Post #782399 21st Jul 2019 4:55pm
Swine&Small
Sounds like it is cooked Big Cry
When this happened to mine ,I took the opportunity to upgrade and get a new one as the cost of new versus repair was not that great I thought. Also , if you have given it a hammering then it may also have worn other bits that are yet to fail completely .
Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #782412 21st Jul 2019 5:25pm
Bluest
If you've got a compressor, chuck the dremel and buy a micro/turbine grinder. One will run fine of a 50l DIY compressor. They are much lighter and easier to hold than a Dremel with no highly strung motor to burn out. 2007 110 TDCi Station Wagon XS
Post #782434 21st Jul 2019 6:44pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Usually when the armature burns out the field coil isn't far behind either. In work I replace both and a set of brushes on drills/breakers etc. Thumbs Up
Post #782447 21st Jul 2019 7:28pm
Yannis
I am actually on the look out for some air tools.
Are there any brands to look for?
Post #782495 22nd Jul 2019 1:01am
Personally I favour CP (Chicago Pneumatic). They tend to be pricey but are industrial tools. At the cheaper end of the market I have had reasonable performance out of SIP tools.
Post #782506 22nd Jul 2019 8:08am
Bluest
I’ve got the. Chicago Pneumatic air micro grinder and love it. If you get one, make sure you keep it lubed, they don’t last if you run them dry. 2007 110 TDCi Station Wagon XS
Post #782616 22nd Jul 2019 7:35pm
TJH1985
Which model is that @bluest?
I’ve always fancied one Mr. Green
Post #782665 22nd Jul 2019 10:19pm
Bluest
This one https://www.cromwell.co.uk/shop/power-tool...PT2696500A 2007 110 TDCi Station Wagon XS
Post #782681 23rd Jul 2019 6:23am
