![]() | Home > Off Topic > Dremel decided to try and quit.... |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Sounds like it is cooked
![]() When this happened to mine ,I took the opportunity to upgrade and get a new one as the cost of new versus repair was not that great I thought. Also , if you have given it a hammering then it may also have worn other bits that are yet to fail completely . ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
If you've got a compressor, chuck the dremel and buy a micro/turbine grinder. One will run fine of a 50l DIY compressor. They are much lighter and easier to hold than a Dremel with no highly strung motor to burn out. 2007 110 TDCi Station Wagon XS
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Usually when the armature burns out the field coil isn't far behind either. In work I replace both and a set of brushes on drills/breakers etc.
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 409 ![]() ![]() ![]() |
I am actually on the look out for some air tools.
Are there any brands to look for? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
Personally I favour CP (Chicago Pneumatic). They tend to be pricey but are industrial tools. At the cheaper end of the market I have had reasonable performance out of SIP tools.
I’ve got the. Chicago Pneumatic air micro grinder and love it. If you get one, make sure you keep it lubed, they don’t last if you run them dry. 2007 110 TDCi Station Wagon XS
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 241 ![]() ![]() |
Which model is that @bluest?
I’ve always fancied one ![]() |
This one https://www.cromwell.co.uk/shop/power-tool...PT2696500A 2007 110 TDCi Station Wagon XS
