Home > Technical > BBUS Chirping |
Harry dog Member Since: 27 Oct 2016 Location: Farnham Surrey Posts: 38 |
Vehicle came back my independent 4x4 garage toady after 4 days with the battery disconnected and now when the ignition is first turned on the BBUS chirps once!!
Garage says they can't find a fault anywhere and they haven't been anywhere near the alarm.....suspect could be low battery but is that low battery on the main vehicle battery or the BBUS and why would it start to happen after the 4 days in the garage? If it is a low battery will it re-charge itself once its been driven for a few days and the chirp will go away? Vehicle is 2012 2.2 Puma. Thoughts? Cheers Harry |
16th Jul 2019 2:48pm |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 |
Mine does that when it's not been used for a while, once it's been out for a decent run it goes away.
16th Jul 2019 3:42pm |
So is it the main battery in the vehicle that needs to charge back up or the one in the BBUS?
16th Jul 2019 9:03pm |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 |
Yes, its the main battery letting you know its a bit low. Give it a charge overnight and the chirping should stop
17th Jul 2019 9:10pm |
Just been back to garage to get the main battery checked.....Its giving a reading of 97% and everything else connected to the system checks out fine......So, the chirping sound from the BBUS can't be low battery level from the main battery?! It surely must be indicating that the battery within the BBUS is low? Thoughts anyone...……...
18th Jul 2019 3:01pm |
