Home > Technical > BBUS Chirping
Harry dog
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
BBUS Chirping
Vehicle came back my independent 4x4 garage toady after 4 days with the battery disconnected and now when the ignition is first turned on the BBUS chirps once!!
Garage says they can't find a fault anywhere and they haven't been anywhere near the alarm.....suspect could be low battery but is that low battery on the main vehicle battery or the BBUS and why would it start to happen after the 4 days in the garage?
If it is a low battery will it re-charge itself once its been driven for a few days and the chirp will go away?
Vehicle is 2012 2.2 Puma.
Thoughts?
Cheers Harry
Post #781693 16th Jul 2019 1:48pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Mine does that when it's not been used for a while, once it's been out for a decent run it goes away.
Post #781704 16th Jul 2019 2:42pm
Harry dog
So is it the main battery in the vehicle that needs to charge back up or the one in the BBUS?
Post #781754 16th Jul 2019 8:03pm
discomog
Wifey's Discovery Sport is off to the stealers on Friday as it keeps telling us that the main battery is low and we should start the engine. Once we get the low battery warning, every time we open a door the alarm chirps. Never does it normally, only when battery is low so may well be the same with Puma 2.2 that the BBUS is reacting to low battery voltage. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #781773 16th Jul 2019 8:37pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Yes, its the main battery letting you know its a bit low. Give it a charge overnight and the chirping should stop
Post #781941 17th Jul 2019 8:10pm
Harry dog
Just been back to garage to get the main battery checked.....Its giving a reading of 97% and everything else connected to the system checks out fine......So, the chirping sound from the BBUS can't be low battery level from the main battery?! It surely must be indicating that the battery within the BBUS is low? Thoughts anyone...……...
Post #782017 18th Jul 2019 2:01pm
