![]() | Home > Td5 > front td5 diff |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
Might just need adjusting. It's not that hard to do but quite a lot of work to remove the front diff compared to the rear.
Oh and yes, that is a lot of play, I wouldn't say thats' normal |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
There is a quick guide to checking the difflock on Ashcroft's website
https://www.ashcroft-transmissions.co.uk/f...faq-s.html 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I would take the dust caps off the centre of the hub and check the drive flange splines for play first.
There will always be more play in the front axle than the rear though as you also have backlash in the CV joint and the halfshaft into the CV additionally to the rear ones. Steve 02' 110 TD5 Double Cab Rebuild Thread |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3336 ![]() ![]() |
It sounds to me like the diff lock is not working, as even if you have excessive play in the front diff then it should still work.
If the front diff (or a half shaft) was completely shot (no drive) then the Land Rover wouldn’t move unless the diff lock was engaged. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8375 ![]() ![]() ![]() |
this sounds like two issues to look at. centre diff lock (CDL) and play in front axle drive train.
so only one wheel on front axle spinning, nothing on the rear spinning with CDL engaged? in which case CDL is not working as designed.
there is not necessarily anything amiss here with LR tolerances but it would be worth checking DM ends as above for play. 1/4 turn play would be normal..... Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
