Home > Maintenance & Modifications > R380 gearbox oil cooler adapter -
Page 3 of 4 <1234>
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
This is hand tight, you can see the out flange is spilling over the hex. I know it’s not perfectly centered but even if you really try is impossible to keep it centred.
Is this normal?
Post #998734 5th Jul 2023 5:17pm
geobloke
Ah Ok I see the problem now. Get yourself a couple of penny washers to go between the AN fitting and the Dowty washer. Add the thread sealant and a ring of sealant between the AN fitting and the washer. It is not pretty but it will work.
The other option is to swap out the An fitting for a different brand - https://www.amazon.co.uk/Mishimoto-MMSPF-1...PMQAvD_BwE
Post #998780 5th Jul 2023 9:30pm
NickMc
I spoke to Dave at Ashcrofts he’s away on his jolly’s, but said he’d reply with some info when he gets back about their kit.
Post #998785 5th Jul 2023 9:36pm
LandymanStefan
Thanks geo they look better suited. The an -8 section should be the same as the torques uk fittings I assume?
I’ve ordered the sealant Thumbs Up
Post #998792 5th Jul 2023 9:52pm
geobloke
No problem. Yes the AN-8 section will be the same as AN is a standardised fitment. Thumbs Up Let us know how you get on Thumbs Up
Post #998794 5th Jul 2023 10:01pm
LandymanStefan
Just realised they dont sell a 8an to m20 from mishimoto with the big flange. Ill wait for my crush washers to arrive and potentially if theyre a good fit use them with the sealer. If not ill order replacement fittings from pioneer and hope they fit the dowtys better Rolling Eyes
Post #998795 5th Jul 2023 10:05pm
geobloke
Post #998796 5th Jul 2023 10:17pm
LandymanStefan
Well the install is done. I’ve fired it up with the transfer box in neutral and run through the gears a couple of times opened the filler and topped up, done this twice but didn’t get any extra in on the second go. Yet to road test it.
I ended up buying some m20 to an -8 fittings from pioneer in the end, he was a pretty good price, probably should’ve got them from there in the first place. Then the dowty washers worked fine. I pre filled the rad bending the pipes up into the engine bay and using a smaller pipe in my gearbox oil syringe filled it up. Made it one hell of a messy job connecting it all up and bolting it to the gearbox but I think most of it stayed in. Got approx 1 litre extra of fluid in.
One nightmare was nipping up the pipes onto the take off block is impossible from underneath. I bolted them to the block under the car then bolted the block to the gearbox but holding the block and doing up the fittings I didn’t have enough purchase so in the end had to strip out the interior and lid the transmission tunnel. Rolling Eyes it was worth doing though as I got a fair bit extra on the top fitting.
Here’s a couple of pictures, apologies I got carried away with mods before I cleaned it after the Pyrenees trip.
Post #999216 8th Jul 2023 4:20pm
LandymanStefan
Post #999217 8th Jul 2023 4:21pm
geobloke
Excellent. Hope you have many many trouble free miles from your R380 now Thumbs Up
Post #999232 8th Jul 2023 5:03pm
LandymanStefan
I’ve got a 750 mile day of towing the penman across France at the end of august. Hopefully the 380 will appreciate it and maybe if I’m really lucky it will help the cabin temperatures a bit too.
Post #999237 8th Jul 2023 5:52pm
Procta
LandymanStefan wrote:
Yes I did look into the bigger sump for the transfer box but in my mind I wonder what the effectiveness is. It sits very close to the exhaust and one of the causes of the transfer box getting so hot could be the gearbox next to it using it as a heat sink. It might be something I add later on though Thumbs Up
we added one to my dads 200 TDI, with him towing, He never said it made any difference at all. So i take it, it wasn't worth the add on, but my mam has noticed the gearbox getting hot though. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #999261 8th Jul 2023 8:40pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I have the bigger sump on my transfer box and a temperature sensor in it I’ve just got back from Croatia and in temperatures of 37c on the motorway the temperature was into the high 90c with long runs. I’m going to fit a cooler for next summer
Post #1005797 29th Aug 2023 7:43pm
geobloke
That is what I found as well and why I fitted the cooler.
Post #1005807 29th Aug 2023 8:02pm
yobbie
What temperatures do you get now you have a cooler fitted?
Post #1005890 30th Aug 2023 10:46am
Page 3 of 4 <1234>
