![]() | Home > My Defender > well ours tried to kill us today |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
40 mph on a country road and "screeeeeeeeeeeeeeee........" as the car decides to lurch hard right. OSR wheel locked solid with no warning. Had it happened a few seconds earlier we would have been a bonnet accessory on a RRS heading the other way.
We'd only been driving perhaps a mile, but the wheel around the hub was warm to the touch, while the brake surfaces were cold. All points to a failed wheel bearing. Not what you expect for 27,000 miles. Off to read my big boys book of wheel bearing changing tips ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Landie Boy Member Since: 15 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
do you have any drive train mods, spacers.. etc?
Jack Last edited by Landie Boy on 30th May 2011 7:03pm. Edited 1 time in total |
Nope. Been bog standard from the day we bought her, fresh from the showroom. Only difference is that we're now running 265/75 BFGs which are actually marginally smaller in diameter than the factory 235/85 TRs (a whopping 2mm smaller in fact)
Jacked it up just now and it's got loads of play and is grinding like a barrel-organ monkey on speed. How the hell we haven't heard it is a mystery. ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
ohh :/ hopefully the damage inside isn't too bad
![]() Jack |
With my luck at the moment I expect it's trashed
Cheers James. Having a proper look at it today so will report back later.
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
every time I've had a wheel bearing replaced, it's needed a stub axle too, and it's never something that anyone seems to have in stock when I have a problem....
![]() CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
Exeter 4x4 always seem to have them when i need one! Cheers
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
wow, good to hear you had a bit of luck and your ok.
if that was a busy A road at 50mph with on coming traffic...... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
It's nothing new though... when I had my "new" 200Tdi 90 back in 1992, all 4 rear wheel bearings died within a year.
When I stripped them out there was hardly any grease at all in them. A friend in the trade who lives near Solihull and dealt with the factory on a regular basis back then, told me that they only use(d) a teaspoon of grease per corner on axle build up! Probably not much more thesedays either. |
